kl84 WROTE:What's xBee 24? How do you connect the xbee to your computer? Using Cytron's SKXBee? You build your own circuit?
didiey WROTE:Actually i juz used usb cable to connect xbee 24 with computer, before that there have to install driver from max stream, however this xbee unable to communicate with modem,therefore this situation make me difficult to programmed it.
robosang WROTE:didiey WROTE:Actually i juz used usb cable to connect xbee 24 with computer, before that there have to install driver from max stream, however this xbee unable to communicate with modem,therefore this situation make me difficult to programmed it.
Are you saying you direct connect USB cable to XBee module or SKXBee? Can we connect directly from USB to XBee module, how and which pin is connected? very curious to know![]()
Actually to load firmware, the SKXBee is ready with that, play with it sometime ago and i accidentally corrupted the firmware,And need to use special step to reload the firmware.
Very weird in the photo you shared, I thought we should select the USB Serial Port (COM 4) instead of the COM9.
daren208 WROTE:I have try the method follow SKBEE firmware corruption restore method and using the function set and firmware version in FAQ. But it still come out withe these command.
Getting modem type....Programming modem...OK
No AT parameters to set
Detected baud rate difference.
Make sure PC and modem baud rate is set correctly
Write Parameters...Complete
The SKBEE firmware version same with XBEE Module ?
