Xctu display standard serial over bluetooth
Postby rockleagles » Sat Jan 05, 2013 12:44 am
Im having problem with my xbee and xctu. Ive installed xctu ver 5.2.7.5 . It display (Standard serial over bluetooth instead of USB serial port. I need help !!! Ive attach some photos
rockleagles
Re: Xctu display standard serial over bluetooth
Postby sich » Sat Jan 05, 2013 4:18 pm
How do you connect your XBee to the computer? Are you using SKXBee? We need to know your hardware setup...
Postby rockleagles » Sun Jan 06, 2013 3:49 am
yesss im using skxbee. i think ive connected like a normal usb connection. ive attach a picture of the skxee connected to my laptop
rockleagles
Postby sich » Mon Jan 07, 2013 10:16 am
If that's the case, it appears that the computer doesn't recognise the SKXBee as USB to Serial device. You should be seeing "USB Serial Port" at COM Port Setup column. Did you successfully installed the driver? You can refer to Driver Installation Guide and download the driver at SKXBee product page.
Postby rockleagles » Mon Jan 07, 2013 1:48 pm
lol okay ididnt realize there's a usb driver installer. will try it now . thanx for the information !! really appreciate it !
rockleagles
