ESPWiFi Shield SHIELD-ESP-WIFI Rev2.0
Postby mujahidmohdsharif » Thu Apr 06, 2017 2:08 pm
hi , I still new with wifi shield , today I try create a simple WiFi server using Arduino Uno + ESPWiFi Shield based on the citron tutorial , then I get an error on serial monitor
" Failed to connect to server. " .
#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <CytronWiFiServer.h>
#include <SoftwareSerial.h>
const char *ssid = "nurliyana23";
const char *pass = "DaniaDarwish626";
IPAddress ip(192, 168, 1 ,242);
ESP8266Server server(80);
                        "Content-Type: text/html\r\n"
                        "Connection: close\r\n\r\n"
                        "<!DOCTYPE HTML>\r\n"
                        "<html>\r\n";
void setup() {
  while (!Serial) {
  if(!wifi.begin(2, 3))
    while(1);
  Serial.println(F("Setup wifi config"));
  wifi.config(ip);
    while(1);
  wifi.updateStatus();
  clientTest();
  espblink(100);
  server.begin();
void loop() {
  serverTest();
void espblink(int time)
  for(int i = 0;i<12;i++)
    delay(time);
void serverTest()
  if(client.available()>0)
      Serial.println(req);
      return;
    Serial.print(F("Request: "));
    client.flush();
    if(req.equals("/"))
      client.print(htmlHeader);
      htmlBody += ipStr;
      client.print(htmlBody);
      String htmlBody="";
      for (int a = 0; a < 6; a++)
        htmlBody += "A";
        htmlBody += String(a);
        htmlBody += ": ";
        htmlBody += "<br>\r\n";
    else if(req.equals("/gpio2"))
      htmlBody += "</html>\r\n";
    else if(req.equals("/info"))
      client.print(toSend);
      client.print("</html>\r\n");
    else
    client.stop();
void clientTest()
  ESP8266Client client;
    client.stop();
    return;
                           "Host: www.adafruit.com\r\n"
                           "Connection: close\r\n\r\n";
    client.stop();
    return;;
  int i=5000;
    delay(1);
    if(i==1) {
      Serial.println(F("Timeout"));
      return;
  while (client.available()>0)
    //Serial.print(c);
    Serial.write(client.read());
  client.stop();
mujahidmohdsharif
Re: ESPWiFi Shield SHIELD-ESP-WIFI Rev2.0
Postby bengchet » Thu Apr 06, 2017 4:21 pm
Please refer to this post. Thanks.
