Okay so if I had:
RF Transmitter 433Mhz
Product code: RF-TX-433
RF Receiver 433Mhz
Product code: RF-RX-433
How do you send data without using serial?
I am using assembly language or PICBasic language.
Thank you.
Gundam WROTE:Receiver giving random numbers..why?
shin WROTE:is there need to use encoder n decoder if there only 2 inputs required to use the RF technology?
if yes which type of decoder and encoder suitable for this project?
A380 WROTE:shin WROTE:is there need to use encoder n decoder if there only 2 inputs required to use the RF technology?
I would recommend you to use PT2262 and PT2272. You try to study the given schematic in the datasheet. Easy understand and easy to use. Good Luck!
