The acceptance of message from other device to Wifi shield
Re: The acceptance of message from other device to Wifi shie
Postby Lim » Fri Mar 24, 2017 3:43 pm
if i use the epresso lite v2.0 ,how much is the max baud rate i can actually use?
Lim
Postby bengchet » Fri Mar 24, 2017 6:15 pm
If you are using espresso lite, it is different story. However for this, baud rate 115200 is okay for serial monitor. Just to clarify, the baud rate is unrelated with the data reception already. I also suggest you use Espresso Lite for file uploads.
Postby Lim » Fri Mar 24, 2017 9:57 pm
so, the default esp8266 baud rate built in the espresso lite v2 is how much?9600 or 115200? thanks yea=)
Lim
