plz i need help in my bluetooth
Postby wavestorm1986 » Tue Dec 29, 2009 9:03 pm
i have a KC Wirefree Bluetooth Module Starter Kit SKKCA-21 and i want to pari it using bluesoliel 6.4 but i cant pair i do not know the problem ??
the bluesoliel can work with my mobile and other type of bluetooth devices very good.is it that if i am using WINDOW 7 i will have this problem ???
thanx for any advice
wavestorm1986
Re: plz i need help in my bluetooth
Postby ober » Tue Dec 29, 2009 9:21 pm
hi wavestorm1986, can you elaborate more on the problem, any message shown? Normally we do not pair it, we just connect it.
If possible please print screen your Bluesoliel and share with us here.
Postby wavestorm1986 » Tue Dec 29, 2009 9:50 pm
hi ober
thanx for reply me sir
i do not know how to upload the pix, but i already upload it using rapid-share
http://rapidshare.com/files/327480987/Image009.jpg (i connect the bluetooth module using a PIC16F and i used the 7 segment to test it using hyper-terminal but also not working)
http://rapidshare.com/files/327481707/1.png
http://rapidshare.com/files/327482194/2.png
plz i need help
wavestorm1986
Postby ober » Tue Dec 29, 2009 11:22 pm
Sorry, I cannot view the pictures.
Postby wavestorm1986 » Tue Dec 29, 2009 11:24 pm
ok then can you plz show me the steps how i can upload the pix ???
Regards
wavestorm1986
Postby wavestorm1986 » Wed Dec 30, 2009 2:08 am
hi there
i will explain to you whats happening when i run the bluesoliel i can find the device and i can see also the IP,but when i want to pair i found a massage from the bluetooth icon says "cant connect to the device, please make sure it is is powered on and connectable"
the bluesoliel driver is working fine but with the module cant pair at all. plz any idea how to fix this issue.
Regard's
wavestorm1986
Postby ober » Wed Dec 30, 2009 9:12 am
Hi, every SKKCA is tested with Bluesoleil before we ship it out. I am not sure what is the problem as described. But when you say pair, you mean to connect it? And what do you mean by IP? I assume you are referring to Bluetooth Address, right?
Anyway can you try to use this version of Bluesoleil because we are using it for testing. You can download it here: http://www.cytron.com.my/usr_attachment/BlueSoleil.zip
You can also download the User's Manual of SKKCA and look for section 6.2 Computer. The User's Manual can be download here: http://www.cytron.com.my/usr_attachment/SKKCA%20User%20Manual.pdf
Postby wavestorm1986 » Wed Dec 30, 2009 7:26 pm
thanx for your help but the bluesoleil that i run from ur link coz me a problem with my memory and i do not know why it like this
so i went back to my bluesoliel 6.4, plz can i know if the module can work with win7 or not ???
wavestorm1986
Postby robosang » Thu Dec 31, 2009 10:04 am
I use SKKCA-21 before, but that is long time ago, I think 1 year ago. It is still working nicely now with my old Bluetooth dongle, not using window 7, so cannot really help you. But I think the OS should not cause any problem as long as it is being installed on the OS. BTW, I am using older version of Bluesoliel too.
Postby sich » Thu Dec 31, 2009 12:37 pm
wavestorm1986,
I've tried to install the version provided by Cytron in my Win7 pc. You are right, blue screen right after i execute the software and pc restarted. Will try with other version and update soon.
