GSM modem
GSM modem
Postby faizun_shev » Wed Feb 10, 2010 2:20 am
i have bought 1 gsm modem with cytron b4 dis. now im having problems in doing the setting of d modem. i try to connect from pc to gsm modem. once the power on, red led will on while green led will blinking. i follow all the setting given in the manual but after set up the hyperterminal, my gsm modem is not functioning after i wrote AT. nothing comes out. suppose 'OK' will come out once I enter the AT . so, hope the engineer can solve my prob.
2) in hyperterminal, what is the area code for msia ?
faizun_shev
Re: GSM modem
Postby waiweng83 » Thu Feb 11, 2010 11:38 am
Hi, please make sure you have selected the correct COM port and baud rate (115200) in your hyperterminal.
waiweng83
Re: GSM modem
Postby faizun_shev » Fri Mar 12, 2010 5:06 pm
i ady follow the manual instructions given by cytron.. even i olso had try differ kind of baud rate.
how to attached the pic ? i want to show u my setting
faizun_shev
Re: GSM modem
Postby A380 » Fri Mar 12, 2010 7:41 pm
load ur photo on this site http://photobucket.com/.. then you copy the Image Code and paste to here... image code is start with [IMG]......
A380
Re: GSM modem
Postby ober » Sun Mar 14, 2010 9:36 pm
might be the serial cable??
Re: GSM modem
Postby faizun_shev » Mon Mar 15, 2010 11:52 am
yaa..absolutely.i ady bought the new one & my prob is settle rite now. tq cytron ;)
faizun_shev
Re: GSM modem
Postby m_syukrie » Sun Dec 05, 2010 3:33 am
you mean your serial cable not function? why it not function?
m_syukrie
Users browsing this forum: No registered users and 39 guests
