SKXBEE Range Test
SKXBEE Range Test
Postby vr_mission » Thu Feb 25, 2010 1:03 am
Hye..
Can some one show me how to do the range test for 2 modules of XBee..I'm using XCTU software to do the range test..Thank you..
vr_mission
Re: SKXBEE Range Test
Postby yonghui » Thu Feb 25, 2010 2:20 pm
vr_mission WROTE:Can some one show me how to do the range test for 2 modules of XBee
range test meant testing how far the xbee modules are able to send and receive? the range for both Xbee and Xbee pro are stated in the user manual.
probably u will like to know the signal strength, RSSI(RX Signal Strength Indicator) of each data receive by the Xbee module. there are 2 ways of knowing RSSI of the data received. the 1st method is setting the pin #6 on xbee radio to be RSSI, using the P0 AT command (PWM0 Configuration).
2nd method will be using API modes. in API modes, every received packets will contain a byte showing the RSSI of the data.
hope this information will be able to help u further your works.
refer to the usermanual of the Xbee radio for more information.
regards
Postby vr_mission » Tue Mar 02, 2010 12:15 pm
Owh..thanks a lot.. :D :D
vr_mission
