GPS Module with GPS Evaluation Board problem
Postby Jiewy » Sun Mar 21, 2010 9:37 pm
Guys i need help here.
I have connected my EB-85A module to the gps eval board. Used a usb connector to connect the board to my pc.
In the cytron website downloaded the MINIGPS and GPS Trace softwares to test the output of the GPS. But.. I am getting nothing..
Have been trying for 2 days already.
Now i am wondering, am i facing problems with my hardware.. like either my module of my eval board? ..
Jiewy
Re: GPS Module with GPS Evaluation Board problem
Postby waiweng83 » Sun Mar 21, 2010 11:29 pm
did you select "USB" at the interface selector switch?
waiweng83
Postby Jiewy » Mon Mar 22, 2010 12:18 am
I did.. Wat about the int and ext. that one i tried both.. DIDnt work as well..
Jiewy
Postby waiweng83 » Mon Mar 22, 2010 10:17 am
The Int/Ext switch is for you to select whether you wan to use the RS232/USB or the TTL level UART to connect to your GPS module.
If your connection is correct, you should see there is a new virtual COM port once you plug in the USB to your PC. In your GPS Trace or MiniGPS, you should select that particular virtual COM port as well. If this still doesnt work, try to change the baud rate and see...
waiweng83
Postby Jiewy » Mon Mar 22, 2010 12:05 pm
Well mine is comport3. Anyway, i am not getting anything from the hyperlink nor am i getting any output from the MINIGPS after changing the baudrate..
Jiewy
Postby waiweng83 » Mon Mar 22, 2010 12:41 pm
Then I got really no idea d. Please contact Cytron's support by filling up the form here: http://www.cytron.com.my/support.php
waiweng83
Postby Jiewy » Mon Mar 22, 2010 12:45 pm
Sry for the trouble. But is there any way that i can check if its my module or my board problem?
Jiewy
Postby Jiewy » Mon Mar 22, 2010 12:54 pm
Do u wanna see my connection via msn or skype?
Jiewy
Postby waiweng83 » Tue Mar 23, 2010 1:36 pm
From your description, seems like you are using GPS module together with the GPS evaluation board right? Is there any custom circuit in your system? If no, I think the best way is to send back both item to Cytron so that the engineer can check it out.
waiweng83
