I tried interfacing the GPS eval board to the PC using the RS232.
And then i used the hyperlink to get the output.
I played around with the baud rate and the thing i got closest to the NMEA output is when it is 38400 but still there are still unreadable characters.
I gave the GPS board 6 V.
When i used the connect the GPS eval board to the PC using the USB connection, i got a clear output from the hyperlink. I measured the voltage of the USB and it is only 5.13V.
Does the difference of voltage affect the outcome of the hyperlink?
