I can't configure XBee using XBee Explorer USB
Postby ngoc_anh » Tue Jul 27, 2010 6:36 pm
I have 1 XBee RF module and 1 XBee Explorer USB.
I plug the module on top of the explorer and use a mini USB cable to connect it with a PC.
Then I access the XBee module through X-CTU software.
It can detect the module after I press Test/Query button.
But when I type "+++", it doesn't reply "OK".
Does anyone know what the problem is?
Thank you,
ngoc_anh
Re: I can't configure XBee using XBee Explorer USB
Postby ober » Wed Jul 28, 2010 4:47 pm
Try to reload the firmware to version 10CD.
USB Explorer should be from Sparkfun, right? The connection should be correct since the X-CTU can read the XBee. Might be your baud rate at the communication window?
Postby ngoc_anh » Thu Jul 29, 2010 9:16 am
Thanks,
I've found out the reason. I have another XBee Pro stater kit and it works perfectly.
So I checked the parameters in Modem configuration Tab and compare them with the XBee RF module.
Under AT Command section, I set the parameters the same as the starter kit since their Guard Times are different.
Then when I typed "+++", it was able to reply "OK". :D
ngoc_anh
Postby ober » Thu Jul 29, 2010 10:01 am
Oh... good to hear that!
