How to attach 65 Channel GPS Receiver with Smart Ant to gps
Postby yemz87 » Thu Aug 12, 2010 12:54 am
How to attach this GPS to GPS evaluation board? pls show me by diagram or pic pls...
and I wanted to know how to integrate GPS module to GPS module to get the latitude, longitude and time of RFID card? by using c# language
yemz87
Re: How to attach 65 Channel GPS Receiver with Smart Ant to gps
Postby shiyan » Thu Aug 12, 2010 8:42 am
8-)
shiyan
Postby robosang » Thu Aug 12, 2010 9:17 am
:lol:, the title also confusing... how to attach a GPS to another GPS? I would like to know too.
Postby yemz87 » Sun Aug 15, 2010 3:07 pm
hah? confuse? I mean GPS receiver to connect with GPS evaluation board...
yemz87
Postby robosang » Mon Aug 16, 2010 9:48 pm
Your title is "How to attach 65 Channel GPS Receiver with Smart Ant to gps", GPS to GPS, din see the evaluation board.
Din go through the 65 channel GPS, but as long as the UART level is same, 5V to 5V, 3.3V to 3.3V should be fine.
Tx to Rx, Rx to Tx pin. power the GPS from the evaluation, common gnd. check whether the GPS module need back up battery to operate, I think that's all! maybe some of the mode pin too. Good luck.
Postby ober » Thu Aug 19, 2010 3:42 pm
Basically robosang is correct.
If you study datasheet of 65 Channels GPS (SUP500F), you will notice that you can power it with 3.0V to 5.5V, but the serial interface is 3.3 LVTTL Level. There are 7 pins, from RXD, TXD, GND, VDD, VBAT, P1PS and PSE_SEL.
While for GPS Evaluation board, though there is not datasheet, but you can refer to the schematic provided to get the necessary information to connect it. You can actually use the pad on the right bottom site of the board, there are 9 blank pads near the USB socket.
What you can try is:
65 Channels GPS GPS Evaluation board
pin 1 = RXD connect to pin 4 = RX
pin 2 = TXD connect to pin 3 = TX
pin 3 = GND connect to pin 2 = GND
pin 4 = VDD connect to pin 1 = 3.3V
pin 5 = VBAT connect to pin 1 = 3.3V (required)
pin 6 = P1PS (leave it unconnected)
pin 7 = PSE_SEL connect to pin 2 = GND (for Enhanced acquisition mode)
try and see, and bare in mind you will need a clear sky to get GPS signal locked. Good luck.
