cannot detect bluetooth device...
Postby sly » Tue Aug 17, 2010 1:38 pm
Erm I used 115200 for baud rate, the parity, stop bit and flow control as the manual shows. It didn't work. Then I tried 9600 baud rates, it is works. is it I'm wrong??
But, when i try connect the skkca with bluetooth dongle, but it failed to detect each other...
and when the bluesoil is launch, it shows INVALID Operation.
so what is the problem??
sly
Re: cannot detect bluetooth device...
Postby robosang » Tue Aug 17, 2010 2:41 pm
Ho ho.... you post similar question at different place :shock:
seem like your Bluesoil is not working.... try searching the forum, I remember that someone discuss about Bluesoil not working in Win7 and Vista.
Postby sly » Tue Aug 17, 2010 8:13 pm
haha,sorry ya...now i have try on KC11 and KC21
ya i got it,but my pc is window xp so i don't think that is window problem.
sum more i also download the bluesoil software that suggested in forum
but still KC 21 still cannot connect...
like you say,when KC21 plug into USB, open HyperTerminal, press reset button, the starter kit has response...but the KC21 only response when i change the baud rate to 9600.
but the problem is why the pc cannot detect the starter kit??
thank you...
sly
Postby ober » Thu Aug 19, 2010 3:21 pm
sly WROTE:now i have try on KC11 and KC21
So you are saying you have 2 type of SKKCA? KC21 and KC11, correct? and both can send event message to computer through USB but the both baud rate is 9600.
That's a bit strange, because the default baud rate is 115200kbps. Our test house will run test with this baud rate (115200 kbps) to check the communication before we ship to customer. The baud rate can be changed using AT command and it can be permanent.
Are both the Bluetooth Starter Kit you have is fresh from Cytron? Or you are using SKKCA from seniors?
