by robosang » Mon Oct 25, 2010 8:35 pm
I think Cytron did provide the simple application, try to search one of their PR. Friend of my bought that before and it work well. It uses Bluetooth dongle to create connection, is easier and basic way.
I did once gone through the datasheet and the document, cannot remember the name. It uses UART only and it need to send AT command. There are 2 modes, command mode and transparent/serial mode. By default the bluetooth is in command mode. you can send command to search for available Bluetooth device and then process the result and send the desire Bluetooth address to establish connection, if the connection is successfully establish, it will turn into transparent mode.
Basically, is UART function, you will need to develop program to store Bluetooth address and send command.
