How to send signal to microcontroller using SKXBee??
Postby kahhoe87 » Sun Oct 31, 2010 12:52 am
Can i send signal from one microcontroller to another microcontroller wirelessly using XBee Starter Kit (SKXBee)??
kahhoe87
Re: How to send signal to microcontroller using SKXBee??
Postby yonghui » Mon Nov 01, 2010 12:59 pm
SK xbee has both the usb for computer usage and the side header pin of connecting to microcontroller. the communication is UART. so you can connect to microcontroller :)
check the schematic, if i remember correctly SKXbee has the level shift of 3.3V/5V already. its convenience. u can connect directly to the 5V microcontroller interface.
Postby shiyan » Mon Nov 01, 2010 9:59 pm
Can :lol: , sure can! The next question you want to ask is how, right?
shiyan
Postby kahhoe87 » Tue Nov 02, 2010 1:15 am
Bingo, i want to know how :D :D
is it program the PIC with c programming language :?: :?:
kahhoe87
Postby kl84 » Tue Nov 02, 2010 4:23 am
Since it's using UART, you can use any language you want. Just follow the protocol and you'll get there.
kl84
