Wireless Data Transmission
Postby PIGBAOBAO » Sun Oct 31, 2010 11:44 am
Hi friend,
I am doing a wireless data transmission base on Cytron DIY project by using cytron product. I am using 315MHz transmitter and receiver and PIC16F877A in my project. Now I was developed a program (mikro-c compiler) and simulated successful for my RF receiver part. Below is my receiver side program;
// LCD module connections
sbit LCD_RS at RD4_bit;
sbit LCD_EN at RD5_bit;
sbit LCD_D4 at RD0_bit;
sbit LCD_D5 at RD1_bit;
sbit LCD_D6 at RD2_bit;
sbit LCD_D7 at RD3_bit;
sbit LCD_RS_Direction at TRISD4_bit;
sbit LCD_EN_Direction at TRISD5_bit;
sbit LCD_D4_Direction at TRISD0_bit;
sbit LCD_D5_Direction at TRISD1_bit;
sbit LCD_D6_Direction at TRISD2_bit;
sbit LCD_D7_Direction at TRISD3_bit;
// End LCD module connections
#define   click_button   RA1
unsigned int num;
char string1[]= "Welcome";
char string2[]= "Final Year Project";
char string3[]= "Wireless Data Transmission";
char string4[]= "Thank You";
char *string;
void Move_Delay() { // Function used for text moving
Delay_ms(500); // You can change the moving speed here
 void main() {
  int i=0;
  TRISA = 0xFF;             //configure PORTA as input
  TRISB = 0xf0;             //configure PORTB as input
  PORTC = 0;                //LED
  TRISC = 0;
  TRISD = 0;
  PORTD = 0x00;
  TRISD = 0x00;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,3,"Wireless Data");
Lcd_Out(2,4,"Transmission");
Delay_ms(3000);
while(1)
if((portb.f0==0)&&(i==0))
Lcd_Cmd(_lcd_clear);
Lcd_Out(1,7,string1);
i++;
if((portb.f0==0)&&(i==1))
Lcd_Out(1,1,string2);
i++;
if((portb.f0==0)&&(i==2))
Lcd_Out(1,1,string3);
i++;
if((portb.f0==0)&&(i==3))
Lcd_Out(1,1,string4);
i=0;
But, the problem is I am confused and not understand about how is a transmitter program should be i used for make the receiver part operate by using RF since the Transmitter part cannot be shown how it work if simulated in Proteus Professional. Can you give me some suggestion or idea about my problem and if can give me a example of transmitter based on my program above?
Could my project going successfully without using UART (UART_write and UART_read) in both transmitter and receiver program?
Thanks for your help, I am really appreciate it! :D Regard!
PIGBAOBAO
Re: Wireless Data Transmission
Postby KSW » Sun Oct 31, 2010 4:26 pm
How r u going to use ur RF module set??? From ur code, i just see u want to display these message only oo??
then RB0_bit r u going to connect to a switch?? and where is ur transmitter gonna to place?? Can specify a bit?@@
KSW
Postby PIGBAOBAO » Sun Oct 31, 2010 5:56 pm
Dear friend,
The reason why i put a switch and make the character display in LCD in the receiver side (program) instead of put the switch in transmitter, it is because i want to make sure the receiver part can build successful in operation by mikro-c compiler. (Operate if receive the digital switch signal.)
(*since the transmitter side we never know how it's function when we are simulated in Proteus Professional so I assumed the switch in receiver side is transmitter signal.)
Here is my transmitter side source code,
#define   click_button   RA0
char *string;
unsigned int adc_rd;
 void main() {
  unsigned int num;
  TRISA = 0x3F;             //configure PORTA as input
  TRISB = 0x00;             //configure PORTB as output
  TRISC = 0x00;             //configure PORTC as output
  num=0;
    while(click_button == 1)
        num++;
        if(num > 3)
           num=0;
        Delay_ms(1000);
So is it work??Is it my concept wrong? Will the RF module continuous send and read signal and only work if any signal is exist? Sorry for my English...
PIGBAOBAO
Postby robosang » Mon Nov 01, 2010 9:34 am
Whole long list of source code, can you please use the proper tools to share the code?
Postby PIGBAOBAO » Mon Nov 01, 2010 10:08 am
Dear friend,
Sorry for inconvenience. It is because i think that's easy for preview, since i am newbiew in c-language and yet mikro-c compiler so I am hope you all can help me check whether the coding is work or not and if i was proceed my rf project without using UART interface and what is the result???
My project is a easy wireless rf project. What is my project want to do is when i pressed a pushbutton in transmitter there will be a digital signal transmitted to receiver and show the character in LCD display.
Can anyone help me in my preview question and if can give me coding(mikro-c compiler) with similar to my project except from the PR16??
PIGBAOBAO
Postby shiyan » Mon Nov 01, 2010 9:32 pm
:shock:
shiyan
Postby ober » Tue Nov 02, 2010 2:30 pm
PIGBAOBAO WROTE:Dear friend,
Hi, please go through our forum rules and regulations if you are new. Pasting source code is not encouraged as non of us is code debugger or checker. If it is unavoidable please use proper tools to share it.
As for your project, the nature of low cost RF module is open to noise/interference, I would still recommend you to send data/signal in uart format and even in better is you could use package format, the discussion here might help you.
Good luck and do let us know the progress.
Postby shahrul » Sun Nov 07, 2010 4:58 am
PIGBAOBAO WROTE:My project is a easy wireless rf project. What is my project want to do is when i pressed a pushbutton in transmitter there will be a digital signal transmitted to receiver and show the character in LCD display.
You state that is easy project. So, why you request for coding? You just learn for your self.
Users browsing this forum: No registered users and 28 guests
