SKXBEE and RS232
SKXBEE and RS232
Postby winfai » Fri Jan 21, 2011 8:54 am
Dear all,
I have question on RS232 and SKXBEE. There are 9 pins in the RS232 such as TX, RX, ground,etc. I would like to ask, can i connect TX , RX, ground of the RS232 to the respective pin of SKXBEE ( RX, TX , ground, reset, 5V)??? I would like to ask, for 5 V pin in SKXBEE, which pin of RS232 should i connect to supply voltage???
My idea of connecting RS232 with SKXBEE
RS232 >>>SKXBEE
TX >>> RX
RX >>>TX
ground >>> ground
nil >>>RESET
???? >>> 5 V
can anyone help me comments on this???
thanks in advance
winfai
Re: SKXBEE and RS32
Postby shahrul » Fri Jan 21, 2011 12:57 pm
SKXBEE is UART interface. The difference RS232 and UART is only voltage level.
UART - High = 5V, Low = 0V
RS232 - High = -12V, Low = 12V
So, to interface this two, you need MAX232 chip. http://shahrulnizam.com/max232-driver/
Re: SKXBEE and RS32
Postby yonghui » Sat Jan 22, 2011 5:11 am
SKXbee has onboard USB-uart chip. u can connect the usb cable to communicate with skxbee. there is no need for RS232 port.
Re: SKXBEE and RS32
Postby ABSF » Sat Jan 22, 2011 5:35 am
Wow, doing research at 5 am on Saturday morning? ;) You are really hardworking.... :mrgreen:
I am going jogging at 5.30 am this morning.
Re: SKXBEE and RS232
Postby winfai » Sun Jan 23, 2011 8:48 pm
Thanks for all the reply.... But the device i am using don't have UART connector, only RS232 and CAN connector... Can i use CAN connector connect with the SKXBEE??? There are three pin on CAN connector such as TX, RX and ground???? Can it work???
thanks in advance
winfai
Postby winfai » Sun Jan 23, 2011 9:50 pm
deleted
winfai
