nicholaswsw WROTE:I install all the driver for XCTU program but Windows show that SKXBEE as Not Recognized USB.
But when i try with another SKXBee its working perfectly fine. What could be the problem?
Since Cytron did not provide the schematics for SKXBee, it looks like there are only a few things you can check.
First, does the green LED for 3.3V light up when USB is connected?
Did you interchange the XBee from the good SKXBee with the faulty SKXBee?
Are there any dry joints on the USB socket?
The next I would suspect the SMD PIC. It has 28 pins and I cant see any crystal around it. And you need to have the desoldering tools and the program for the PIC before you can undertake the repairs. Is the faulty SKXBee still under warranty (6 months)? If yes, the best answer is to send it back to cytron for repair.
