hi...can i know how to control PT2262 using PIC? issit possible if i send a low pulse to PT2262?
one more thing, the value of the resistor at both oscillator will affect data to send?
Answer is appreciated!
gajian88 WROTE:hi...can i know how to control PT2262 using PIC? issit possible if i send a low pulse to PT2262?
shahrul WROTE:Are you going to do RF Module? Why not you directly RF Module to PIC without PT2272.
ABSF WROTE:gajian88 WROTE:hi...can i know how to control PT2262 using PIC? issit possible if i send a low pulse to PT2262?
A low pulse to 2262 /TE pin is to enable the sending of the encoded codes to the 2272 end. On the 2272, a valid receive is indicated by a logic high on the VT pin.
