davidtsj WROTE:What should i do with these hardware..how should i start to transmit and receive data between 2 xbees(one connected to another mc and the other connected to another mc on a different breadboard) in order to blink LEDs to prove simple tranmission of data..thx in advance..
Take Shahrul's advice and do what he suggested.
If Button->PIC->UART->Xbee XBee->UART->PIC->LED is still too tough for you, You can always try without the XBee first. Just connect UART to UART and use your PBP program to make it work first. If it works, add in the XBee and try again. Since PIC can work on 3.3V, inter-working should be no problem.
You can refer to the discussion here. Instead of reading the ADC and send to the other XBEE, you can change it to read a button.
http://www.picbasic.co.uk/forum/showthr ... light=xbeeAllen
