output TTL 3.3v and SXBEE
Postby winfai » Thu Mar 17, 2011 10:38 am
HI all,
Can output TTL 3.3V be used with SKXBEE??? This is very important for me... If not, what should i do?
thanks for reply
winfai
Re: output TTL 3.3v and SXBEE
Postby ABSF » Thu Mar 17, 2011 2:11 pm
Which part of SKXBee are you interfacing?
The USB part can be connected directly to the PC. The UART part is +5V tolerant if I am not wrong. You dont need to use 3.3V part to interface unless you are talking about OEM XBee. Then you'll need 74LVC4245 level shifters.
