2 SKXBee send and receive Data
Postby lambertlai » Tue Aug 16, 2011 3:15 am
I using 2 SKBee for send and receive data information.
I connect to Arduino board (use battery only, no USB cable), which mean 1 SKXBee connect Arduino board function is send or receive data information,
anothe SKXBee connect to USB and PC monitoring, edit or send back to Arduino board the data information.
So how to configuration the XCTU and the Arduino code? Thanks
lambertlai
Re: 2 SKXBee send and receive Data
Postby yonghui » Sat Aug 20, 2011 9:13 am
for xtcu not much things u can configure. u will need to set the correct baudrate according to the xbee module. then go to terminal tab, thats the place the data in out will be display, u can click on show HEX button to show hexadecimal values of the data. if u wish to send packets of data u can click Assemble packet button.
u can develop gui and computer side too, cytron's robot head to toe magazine has an example program for that. pls refer
on the arduino board, programming to control the uart serial communication is needed.
Postby hyng » Sat Aug 20, 2011 10:03 am
We just come out with a tutorial on SKXBee. Please follow the tutorial below :P
http://tutorial.cytron.com.my/2011/07/30/xbeexbee-pro-wireless-communicate-with-microcontroller/
Postby hyng » Sat Aug 20, 2011 10:06 am
For Arduino with XBee, here is another tutorial.
http://tutorial.cytron.com.my/2011/08/13/project-14-wireless-temperature-logging/
Please go through it and try to test on them. ;)
