COM port is correctly selected, baud rate correctly selected, every settings are the same as instructed in the forum site.
P.S. The SKXBee should not be made in such a way that XBee antenna is soldered so firmly on the board, it should be completed with female 2mm pin headers so that the XBee is detachable and users can use the Starter Kit board to configure another XBee anternna.
