Help! Xbee AT command.
Postby Myline » Sun Dec 18, 2011 10:59 am
Hi guys,from cytron tutorial,the example show 1 way digital communication rite.
Somebody know how to modify it to become analog form
which means the system is continuously monitoring in every second.
AT command for two Xbeepro
Myline
Re: Help! Xbee AT command.
Postby Myline » Sun Dec 18, 2011 11:11 am
There are many pins for input and output in Xbee pro either analog or digital form,
what command is used to specific the destination i set to input(digital form) Xbee.
For example,if my input is link to one sensor,then sensor(digital form)
is specific to 1 destination of input(digital form) on Xbee.What command is using for?
Simple word,a digital sensor link to input of Xbee using what command
used to specific the destination of input and in digital way communication...
PIN signal for Xbee pro
Myline
Postby ober » Mon Dec 19, 2011 2:57 pm
You can refer to one of Cytron's DIY project, PR20: XBee-Standalone Control and Monitoring. It configure the analog input on the receiving site and output PWM on another XBee module. Should be helpful.
Postby Myline » Wed Dec 21, 2011 10:24 pm
thank a lot ^^
Myline
