trigger the IO port of xbee
Postby lockman_akim » Tue Jan 31, 2012 2:28 pm
hye everyone,
is that possible to trigger the IO port of xbee module when it receive a serial data. For example, when it receive "B" (ASCII) then the D0 port will turn high. Can it work? if yes, how to set it and what is the AT command?
lockman_akim
Re: trigger the IO port of xbee
Postby sich » Thu Feb 02, 2012 4:38 pm
I'm not familiar with XBee but afaik user cannot run custom code on XBee module.
A quick search yields Programmable XBee. However, this product is not in Cytron's list.
If you want to read analog value on XBee #1 and output PWM on XBee #2, it's possible.
