Xbee Configuration
Xbee Configuration
Postby JTWC » Sat Mar 17, 2012 12:03 am
I am using Digimesh 2.4 firmware 8062 , trying to create a network that support multihop and multipoint.
All the xbee module will be connected to a laptop by the SKXBEE, i need help configuring the module ,so each module can send and read data.I am using the xctu software to send and read the data.
JTWC
Re: Xbee Configuration
Postby robosang » Sat Mar 17, 2012 10:55 am
Never use Mesh network before 8-) , so what is the configuration needed? If you use X-CTU, refer to the datasheet or the mesh networking manual you should able to get the configuration right?
Postby shahrul » Tue Mar 20, 2012 2:29 pm
Just setup all XBee with same ID. I don't know detail, but with same ATMY and ATDL. If 2 XBee can communicate, the multipoint wireless is only depends on microcontroller programming.
