XBee problem, Please Help.
Postby soongkhim » Wed Apr 04, 2012 9:56 am
Hi, lets say i wan to transmit 0xAA, and i connect directly XBee Din pin direct to TX pin of pic controller. Is it ok that i do the conection, since pic controller output '1' is 5V. Will it break the XBee's Din pin?
I supply 3V to XBee.
What the the default baud rate for the XBee series 1?
soongkhim
Re: XBee problem, Please Help.
Postby shahrul » Wed Apr 04, 2012 11:02 am
That is no problem connect PIC TX direct to XBee Din, but you have choice better to put 100 ohm between that.
Baud rate normally 9600.
Postby robosang » Thu Apr 05, 2012 11:28 am
Have you configure the XBee?
Postby soongkhim » Thu Apr 05, 2012 3:03 pm
i have problems with XBee. I connect microcontroller direct to XBee, but it does not work.
i hv 2 Xbee, 1 acts as a transmitter and the another acts as 1 receiver.
for the transmitter side, Din of XBee pin is connect to TX pin of pic controller, while for receiver side, Dout pin of xbee is connect to RX pin of controller.
both XBee's RTSbar is connect direct to 3.3V. both xbee gnd and controller gnd is connected.
please advise. thanks ...
soongkhim
Postby soongkhim » Thu Apr 05, 2012 4:35 pm
robosang WROTE:Have you configure the XBee?
do i need to configure the xbee first before using it??
soongkhim
Postby hyng » Fri Apr 06, 2012 5:32 pm
Well.. not familliar with XBee. But i think you need to set the address for each XBee.
There is some tutorial on using the Xbee.. pls refer to them.
