recommendation RF to control home appliances .
Postby kitz » Wed Sep 26, 2012 9:48 pm
i new here just ask for your recommendation that which product are suitable to control home appliance
i have check that XBee but dunno which are more suitable for my project.
thanks.
kitz
Re: recommendation RF to control home appliances .
Postby yonghui » Wed Sep 26, 2012 11:01 pm
Postby kitz » Fri Sep 28, 2012 8:20 am
thanks for replying.
Preferable for Xbee, can i know the different between Xbee S1 & S2 about 802.15.4 firmware ?
Also is it compatible for android to control Xbee?
thanks
kitz
Postby kitz » Wed Oct 03, 2012 11:05 am
i just want to know how many Xbee that i needed and other part that will be used in my project(RF to control home appliances).
Please help give me suggestion which i needed as example (how many Xbee needed (series 1 or 2) and what else i needed)
Hope your will give me some guidance.
Thanks
kitz
Postby robosang » Wed Oct 03, 2012 11:15 am
It depends how many nodes you need, each node will require 1 XBee (if you wanted to use XBee). Or you can utilize the IO on XBee module and connect few sensors or few outputs together to 1 XBee. Or you can add a microcontroller to do the control and monitor, while the XBee for wireless communication.
Postby kitz » Wed Oct 03, 2012 8:13 pm
okey,
if i use 2 XBee will both also can be transmit and receive ?(sorry i quite blur on this part)
also if i use XBee what should the other thing i need to buy ? (as i know SKXBee . Other than that what i needed ?)
besides that, can i know how long the shipping? in peninsular Malaysia
sorry for asking "noob" question here
thanks.
kitz
Postby yonghui » Wed Oct 03, 2012 9:10 pm
Xbee is transceiver, means it can transmit, also can receive. if u wan to use s1 then both xbee module use s1 if u want to use s2 then both s2.
shipping i think fast.
Postby kitz » Thu Oct 04, 2012 12:43 am
about the part that i needed what else from your opinion ?(2 x XBee , 1 x SKXBee, and any?)
the internet price include shipping fee ?
I hope you can give me some suggestion.
kitz
Postby sich » Fri Oct 05, 2012 12:52 am
You may need 2x SKXBee OR 1x SKXBee + 1x XBee Breakout Board depends on how you design your system. This is because the Xbee pins are not 100mil pitch-to-pitch so it cannot be directly plugged into the standard prototyping boards, unless you design your own PCB.
Postby kitz » Wed Oct 10, 2012 9:59 pm
thanks sich,
By the way, what kind of software that i need to use if i use XBee series 1 or series 2 ?
For the software part what language will be used to write the program?
Also, the software is provided (free)?
kitz
