Monitoring parking lot availability via ZigBee and GSM
Postby yeech » Tue Oct 02, 2012 1:33 pm
Hello,
I need some guidance and basic info.
I would like to use zigbee module on parking space detection and using GSM module to receive the signal.
Can I request for recommendation on the zigbee, others module and components that I will need?
For this, I may need need a zigbee module, a parking board with sensor and a GSM module to tranceive data.
So, in your opinion, what kind of cytron product that will recommended here?
Please provide me with some link and file that related.
Thank you so much.
yeech
Re: Monitoring parking lot availability via ZigBee and GSM
Postby shahrul » Tue Oct 02, 2012 3:47 pm
You can use
XBee product
GSM product
The related document have at their sale page.
You need experience on using UART. Using 2 UART device in 1 PIC is tough (I don't know the spelling, even I google translate didn't find the phrase :D ) because normal PIC only have 1 UART. But, to solve I always use multiplexer and demultiplexer 74HC4052.
Postby yonghui » Tue Oct 02, 2012 8:58 pm
mayb u can use this sensor to detect the space. but i think will need to find out the way to mount it to a suitable place.
http://cytron.com.my/viewProduct.php?pcode=SN-E18-B03N1&name=Digital%20Infrared%20Sensor
Postby yonghui » Tue Oct 09, 2012 1:16 pm
cytron has just posted a new sensor, mayb this one will work better. up to 80cm!
http://www.cytron.com.my/viewProduct.php?pcode=SN-E18-D80NK
Postby yeech » Sun Oct 14, 2012 11:16 am
Is there any sensor from cytron can be use for vehicle detection in outdoor parking which seems convenient and resonable to be implement?
Thank you. :)
yeech
Postby yeech » Sun Oct 14, 2012 2:26 pm
Another doubt here.
Is it SIEMENS TC35 GSM Development Board same function with GSM modem?
If my concern is just send and receive msg is it SIEMENS TC35 GSM Development Board will do?
Thank you.
Regards.
yeech
Postby shahrul » Sun Oct 14, 2012 6:10 pm
yeech WROTE:Hi,
Another doubt here.
Thank you.
Regards.
Siemens TC35 GSM also GSM Modem, can work to send and receive SMS.
Postby yeech » Wed Apr 17, 2013 9:45 pm
Is it the GSM development board need to be in 3G coverage area only it works?
I am trying to run a testing program on GSM but it is not working.
My doubt is not sure whether is my SIM card problem or other problem.
Any SIM card will do right?
Thanks if anyone can solve my doubt.
yeech
Postby waiweng83 » Thu May 09, 2013 11:25 am
It does not need to be in 3G coverage area.
waiweng83
Postby atuk5259 » Fri May 24, 2013 10:10 am
You can also use wifi module, low cost and no need center controller to manage data. using HTTPrequest funct to communicate with multi client module. database using mysql or csv file....also support email,and sleep mode.
Controller flyport module http://www.openpicus.com/site/products
Programming language using IDE http://wiki.openpicus.com/index.php?title=OpenPicus_IDE
atuk5259@gmail.com
atuk5259
