cannot call gsm modem
Postby kechiksp89 » Thu Nov 01, 2012 5:48 pm
hi.i implement the sample source code that has been provided by cytron with the gsm modem that is GSM Enabled Smart Home.I manage to connect the circuit with the gsm modem.problem is that when i make a call to the gsm modem,it was a success but the program return an ERROR dislplay at the lcd>anyone can help?
kechiksp89
Re: cannot call gsm modem
Postby robosang » Sat Nov 03, 2012 6:11 pm
Why don test it with computer?
BTW, you must also study the example code, cannot expect it to work perfectly :twisted:
Postby kechiksp89 » Sun Nov 04, 2012 11:33 am
i have connected the modem with the computer using serial communication and it works out.after i modified the coding it also work but why does the modem did not respond to the command.the modem did not respond with "OK" and ">".
kechiksp89
Postby robosang » Sun Nov 04, 2012 5:30 pm
So you are saying when the modem is connected to computer, there is response of command?
