Can't display proper character for hyperterminal
Postby Ferdinand91 » Thu Nov 15, 2012 2:11 pm
I try to type AT using hyperterminal to test my gsm modem but it show the character that i don't know what is that. may i know which one i need to set so that it can display the character for hyperterminal
Ferdinand91
Re: Can't display proper character for hyperterminal
Postby robosang » Thu Nov 15, 2012 2:42 pm
Printscreen the Hyperterminal and show us.
Postby Ferdinand91 » Fri Nov 16, 2012 12:18 am
i type the 1st row is AT and i press enter it come out chinese word
Ferdinand91
Postby robosang » Fri Nov 16, 2012 9:53 am
Never see this, but 1 weird setting is the "VT100J" under the HyperTerminal window, beside the 9600-N-1. Normally is Auto-detect or ANSI or ANSIW 8-)
Try to change it and check whether it is fixed, not sure is that setting causing the problem.
Goto File->Properties, the Properties window will appear, click the Settings tab, You will see Emulation dropbox, choose ANSI or ANSIW, and click OK.
Postby Ferdinand91 » Fri Nov 16, 2012 11:43 am
may i know the ASCII setup need to set anything or not??
Ferdinand91
Postby Ferdinand91 » Fri Nov 16, 2012 3:34 pm
robosang.......i had try what u had told me just now....eventually i type AT and it did not reply me OK or anything else.
Ferdinand91
Postby sich » Fri Nov 16, 2012 5:32 pm
Postby Ferdinand91 » Sat Nov 17, 2012 10:46 am
sich......i not very familiar using realterm
Ferdinand91
Postby zhenning » Sat Nov 17, 2012 7:31 pm
zhenning
Postby sich » Mon Nov 19, 2012 9:08 pm
Ferdinand91 WROTE:sich......i not very familiar using realterm
There's always a first time ;)
Users browsing this forum: No registered users and 25 guests
