Changing Xbee s1 wire antenna to SMA connector
Postby MarwanShaheen » Fri Dec 21, 2012 12:56 pm
Hi all
did anyone succeeded in changing the wire antenna on xbee s1 (1mW) model and attached an SMA connector? if someone did please provide with as much explanation as possible because the data sheet of xbee for digi does not provide any information regarding the antenna part of the model.
Thank you.
MarwanShaheen
Re: Changing Xbee s1 wire antenna to SMA connector
Postby robosang » Sat Dec 22, 2012 4:18 pm
Don think people will modify it. You can get the SMA type XBee. Hacking the Antenna is not wise move.
