Changing Xbee s1 wire antenna to SMA connector
Hi all
did anyone succeeded in changing the wire antenna on xbee s1 (1mW) model and attached an SMA connector? if someone did please provide with as much explanation as possible because the data sheet of xbee for digi does not provide any information regarding the antenna part of the model.
Thank you.
Thank you.
