RF Module and USB to Serial converter
Postby Chonghan90 » Thu Mar 07, 2013 6:26 pm
Hi all,
I plan to doing a messaging application that using 433Mhz RF transmitter and receiver between two PC.
I am thinking to connect the RF module to USB to serial converter.
Here, is it work to connect RF module with USB to serial converter?
I will program an application for user to enter message, the message will encryption and send to USB COM Port and transfer to RF module for transmission to another PC. But is it ok with my planning?
thanks in advance.
p/s: need to confirm it so that i can proceed to other method if it can' t work. Is out of time now..LOL
Chonghan90
Re: RF Module and USB to Serial converter
Postby shahrul » Fri Mar 08, 2013 8:53 am
Use Low Cost RF Module have many noise in the signal. So, you need spend more time to do programming for filtering the data.
For easier, spend more money to use XBee.
Postby yonghui » Sat Mar 09, 2013 12:19 pm
u can refer to this tutorial from cytron.
http://tutorial.cytron.com.my/2012/04/0 ... less-uart/
