SKBEE can't bet DETECTED by the X-CTU
PostPosted: Thu Mar 14, 2013 7:15 pm
by HUSSEINMOHSEN
hello and very good evening to all brilliant people...
guys I need your kind help
I have bought two xbee-s1, and SKBEE (without module), I have setup the X-CTU software and follow the xbee tutorial as it is, I have updated the formware, and the X-CTU could find the COM PORT, but when I press "READ" it shows me "can't communicate with modem" as figure1
I have followed the same instructions for firmware corruption as the link below:
http://forum.cytron.com.my/viewtopic.php?f=10&t=3380&p=3676&hilit=XBee+firmware#p3676
after that I pressed "WRITE" not "READ", and then it showed me the "wrong write to modem" as figure2
please help me as your much possible,,, thanks to all in advanced...
Re: SKBEE can't bet DETECTED by the X-CTU
PostPosted: Fri Mar 15, 2013 11:20 am
by hyng
Have you succeed to test/query the XBee module?
PostPosted: Fri Mar 15, 2013 1:08 pm
by HUSSEINMOHSEN
Nope, as many as I try to test/query ... it displays figure 1 for me
PostPosted: Sat Mar 16, 2013 7:58 am
by robosang
Are you choosing the correct COM port? Is the driver for COM being installed correctly?
I have this before for my XBee module, but I re-load the firmware and it works fine.
PostPosted: Fri Apr 12, 2013 12:06 am
by nuffy
just go to digi international website for manual xbee reboot...i also got that problem..you have to go to terminal ( on tne xctu) then select and deselect some box and then u type "B" on the terminal..it will manually boot your xbee..my xbee gone crazy after i set to end device, the loading was not even finish correctly..my pc cannot detect my xbee.the led on skxbee also not blinking like always...after i did all the process ..BAMM!! myxbee works fine now...i hope this will help you..
