Flow rate monitoring web server
Postby leeweejohn » Fri Jul 12, 2013 8:27 pm
Guys,
Is it possible if i stack an Xbee shield on top of the ethernet shield, and achieve wireless communication using Xbee S2?
The sensor will be on another module of arduino uno+xbee shield+xbee. And the web server host will be arduino uno+ethernet shield+Xbee Shield+Xbee. The readings of the sensor will be transmitted to the web server host and the readings will be displayed on serial monitor.
Is this possible? Appreciate detailed explanation or any links related.
Regards,
leeweejohn
Re: Flow rate monitoring web server
Postby robosang » Tue Jul 16, 2013 4:07 pm
Detailed explanation? :mrgreen:
