Xbee Series 2 cannot configure
Postby NAIFOO » Wed Nov 20, 2013 1:10 am
Hi. I have problem while configure my Xbee series 2 using SKXBee. When I run the Test/Query, it pop up a window which states Action Required. I followed the steps by it didn't respond. I already updated the latest version of firmware from Digi website but still didn't work. The model I used is XB24-Z7WIT-004 revision K Manufacturing date 080313. Is there any solution regarding to this problem ? Thank you.
NAIFOO
Re: Xbee Series 2 cannot configure
Postby robosang » Wed Nov 20, 2013 9:30 am
What steps did you followed?
Postby yonghui » Wed Nov 20, 2013 3:16 pm
Did u select correct baudrate? Pls try to reset to default .
Postby NAIFOO » Wed Nov 20, 2013 10:31 pm
I pressed and released the Reset Switch on SKXBEE, but the dialog box didn't close within 10 seconds. Yes, I already tried all baudrates, including 9600 but still didn't work. Is it possible that my Xbee module malfunction in this case ? If yes what should I do ?
NAIFOO
Postby yonghui » Thu Nov 21, 2013 11:26 am
U update the firmware successfully previously? If yes means that its working previously. After the new firmware it's not working any more. Try restore to previous firmware See how?
Postby waleed020 » Thu Mar 26, 2015 4:48 pm
i have a problem that the sk40c power does not up..suppose the led power will light up when i attach the ac adapter..but the led does not up..but the sk40c is heat..with this i attach with the picture..i have circle the led power that should be light up..
aliiii
waleed020
Postby ober » Thu Mar 26, 2015 5:00 pm
Please open another topic, and attach the picture 8-)
