Hi dadieaxmal,
Of course you can connect Android bluetooth to Bluebee. There have many Android apps that available in play store that you can use for this purpose. For example you can try
Arduino BT Joystick Free apps. What you need to know is the data received from that apps. So, to check it, try this step:
- Connect your Bluebee and Skxbee to your laptop/PC, make sure you know its COM port number.
- Open any telnet software (e.g. HyperTerminal or RealTerm) on your laptop/PC, select your Skxbee COM port.
- Open Arduino BT Joystick Free at your Android phone, connect to your Bluebee.
- Touch any button on the apps, you will see the data display on the telnet software each time you touch the button.
Those data is UART, so you can program your microcontroller to do any action based on that data.
If you want to sent data from Bluebee to your Android phone, you can try
BlueTerm apps.
