Convert baud rate 34800 (Sensor Atlas Scientific) to baud ra
Postby Hidayah » Fri Dec 20, 2013 4:22 am
hye there....please help me...
i want to send data from sensor that read by arduino uno to zigbee (Xbee)....at hyper terminal, the data had been display by using com arduino. but the problem is i want to get the data from xbee.. im used 2 xbee, first is transmitter and second is receiver.. the xbee cannot display the data because difference baud rate...
how i want to convert the data baud rate 34800 to 9600?
Hidayah
Re: Convert baud rate 34800 (Sensor Atlas Scientific) to bau
Postby robosang » Mon Dec 23, 2013 9:52 pm
Just change the baudrate in Arduino lah.... Arduino Serial.begin
BTW, is 34800 or 38400?
Postby shahrul » Mon Dec 23, 2013 11:41 pm
pH sensor use baudrate 38400, XBee use baudrate 9600.
You can't connect sensor directly to XBee.
There is 2 way.
1. Change baudrate XBee to 38400, using X-CTU
2. Use Arduino to interfacing both. Use 2 Serial Port or software serial.
Postby atuk5259 » Tue Dec 24, 2013 1:09 am
another way is change baudrate for ph controller....pls refer datasheet first...i think module from atlas scientific got command to change baudrate....
atuk5259
Postby sahniana » Wed Jun 04, 2014 12:29 pm
for ph circuit 5.0, to change baudrate from 38400 to 9600
1. connect at default baudrate 38400.
2. send "z4" + <cr> @ chr(13)
3. disconnect.
4. connect at baudrate 9600.
sahniana
