Can XBee Wifi transmit data to XBee Pro?
Postby plianghee » Fri Oct 31, 2014 12:11 pm
Can I transmit data from XBee Pro (XB24-ZB, without Wifi model) to the XBee-Wifi module (XB24-WF)?
plianghee
Re: Can XBee Wifi transmit data to XBee Pro?
Postby ober » Fri Oct 31, 2014 2:15 pm
No, you cannot...
Postby plianghee » Fri Oct 31, 2014 5:24 pm
Thanks for the reply,
using 2 XBee-Wifi, if the remote XBee-Wifi are in no wifi connection access area, can it use RF signal to transmit data to Base XBee-Wifi module? 2 Xbee-wifi module distance ~ 10meter.
plianghee
Postby Idris » Fri Oct 31, 2014 10:59 pm
Hi plianghee,
Xbee WiFi only can communicate in WiFi network. It cannot change to RF or other types of communication protocol. If you still need your remote device communicate in RF (in case no WiFi network), then you need to add RF module in your board (master and slave).
