How to use Range Test for XCTU software
Postby MystizKhoo » Wed Mar 18, 2015 9:10 pm
How to use range test for skxbee (xBee S1) where loopback jumper is needed? (The result I get is transmit 10, receive success 0)
PS: XCTU version 6.1.0
Imagination should be used,
not to escape reality,
but to create it.
MystizKhoo
Re: How to use Range Test for XCTU software
Postby ober » Thu Mar 19, 2015 10:10 am
Can you explain more about the setup on the X-CTU and the XBee?
Postby MystizKhoo » Sat Mar 21, 2015 9:20 pm
Hi, just managed to solve myself by setting the remote xbee in AT mode and local xbee in API(1) mode. Connected the remote xbee to CTUNO and programmed the CTUNO to loopback function. Thanks :D
but to create it.
MystizKhoo
Users browsing this forum: No registered users and 55 guests
