How to use ESP8266 Wifi Module
Re: How to use ESP8266 Wifi Module
Postby ytphua » Wed Feb 03, 2016 11:37 am
Hi
I am yet to try on external power source. My code is as attached. Please advise if there is any bugs.
Code: Select all
#include <CytronWiFiShield.h>
#include <CytronWiFiServer.h>
#include <SoftwareSerial.h>
#define ssid "xServer"
#define pass "a12345"
//IPAddress ip(192, 168, 1 ,242);
ESP8266Server server(80);
  HC-SR04 Ping distance sensor]
  VCC to arduino 5v GND to arduino GND
  Echo to Arduino pin 13 Trig to Arduino pin 12
  Red POS to Arduino pin 11
  Green POS to Arduino pin 10
  560 ohm resistor to both LED NEG and GRD power rail
  More info at: http://goo.gl/kJ8Gl
  Original code improvements to the Ping sketch sourced from Trollmaker.com
  Some code and wiring inspired by http://en.wikiversity.org/wiki/User:Dstaub/robotcar
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
long distance;
const char htmlHeader[] = "HTTP/1.1 200 OK\r\n"
                        "Content-Type: text/html\r\n"
                        "Connection: close\r\n\r\n"
                        "<!DOCTYPE HTML>\r\n"
                        "<html>\r\n";
void setup() {
  // put your setup code here, to run once:
  while (!Serial) {
  if(!wifi.begin(2, 3))
  Serial.println(wifi.firmwareVersion());
  Serial.print(F("Mode: "));Serial.println(wifi.getMode());// 1- station mode, 2- softap mode, 3- both
  Serial.println(F("Setup wifi config"));
  //wifi.config(ip);
  Serial.print(F("Connected to: "));Serial.print(wifi.SSID());
  Serial.print(F(", "));Serial.println(wifi.RSSI());
  Serial.print(F("IP address: "));Serial.println(wifi.localIP());
  Serial.print(F("Status: "));Serial.println(wifi.status()); //2- wifi connected with ip, 3- got connection with servers or clients, 4- disconnect with clients or servers, 5- no wifi
  server.begin();
  espblink(100);
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(led, OUTPUT);
  //pinMode(led2, OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
  long duration;
  digitalWrite(trigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(trigPin, HIGH);
  //  delayMicroseconds(1000); - Removed this line
  delayMicroseconds(10); // Added this line
  duration = pulseIn(echoPin, HIGH);
  distance = (duration / 2) / 29.1;
  if (distance > 4 && distance < 30) {  // This is where the LED On/Off happens
    digitalWrite(led, HIGH); // When the Red condition is met, the Green LED should turn off
    //digitalWrite(led2, LOW);
  else {
    digitalWrite(led, LOW);
    //digitalWrite(led2, HIGH);
  if (distance >= 300 || distance <= 0) {
    Serial.println("Out of range:" + distance);
  else {
    Serial.print(distance);
    Serial.println(" cm");
  serverTest();
void espblink(int time)
  for(int i = 0;i<12;i++)
    wifi.digitalWrite(2,wifi.digitalRead(2)^1);
    delay(time);
void serverTest()
  if(server.hasClient())
    Serial.println(server.uri());
    if(server.uri().equals("/"))
      IPAddress ip = wifi.localIP();
      String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
      server.print(htmlHeader);
      String htmlBody = "Hello from ESP8266 at ";
      htmlBody += ipStr;
      htmlBody += "Distance: ";
      htmlBody += distance;
      htmlBody += "</html>\r\n\r\n";
      server.print(htmlBody);
    else if(server.uri().equals("/analog"))
      String htmlBody="";
      for (int a = 0; a < 6; a++)
        htmlBody += "A";
        htmlBody += String(a);
        htmlBody += ": ";
        htmlBody += String(analogRead(a));
        htmlBody += "<br>\r\n";
      htmlBody += "\r\n</html>\r\n";
    else if(server.uri().equals("/gpio2"))
      wifi.digitalWrite(2, wifi.digitalRead(2)^1);
      String htmlBody="GPIO2 is now ";
      htmlBody += wifi.digitalRead(2)==HIGH?"HIGH":"LOW";
      htmlBody += "</html>\r\n";
    else if(server.uri().equals("/info"))
      String toSend = wifi.firmwareVersion();
      toSend.replace("\r\n","<br>");
      server.print(toSend);
      server.print("</html>\r\n");
    else if(server.uri().equals("/chat"))
      server.setTimeout(180);// set 3 min for reply before disconnecting client
      unsigned long timeIn = millis();
      while(Serial.available()<=0&&timeIn+175000>millis());
      //server will return what you have sent in serial monitor
      //max characters 64
      if(Serial.available()>0) server.write(Serial);
      server.setTimeout(10);
    else if(server.uri().equals("/connect"))
      delay(100);
      if(!clientTest())
        server.print("Connection failed\r\n");
    else
      server.print("HTTP/1.1 404 Not Found\r\n\r\n");
    server.closeClient();
bool clientTest()
  const char destServer[] = "www.adafruit.com";
  ESP8266Client client;
  if (!client.connect(destServer, 80))
    Serial.println(F("Failed to connect to server."));
    client.stop();
    return false;
  wifi.updateStatus();
  const char *httpRequest = "GET /testwifi/index.html HTTP/1.1\r\n"
                           "Host: www.adafruit.com\r\n"
                           "Connection: close\r\n\r\n";
  if(!client.print(httpRequest))
    Serial.println(F("Sending failed"));
    client.stop();
    return false;
  // set timeout approximately 3s for server reply
  int i=3000;
  while (client.available()<=0&&i--)
    delay(1);
    if(i==1) {
      Serial.println(F("Timeout"));
      client.stop();
      return false;
  String s, line;
  while (client.available()>0)
    s=client.readStringUntil('\n');
    if(s.indexOf('\r')==-1)
      line+=s;
  server.print(line);
  client.stop();
  return true;
ytphua
Postby bengchet » Wed Feb 03, 2016 3:48 pm
We have looked into your problem. The problem comes from hardware limitation. Avoid use pin 12 as input pin as it will always be HIGH once you powered up everything. Originally it is designed for microSD SPI communication and that pin will always be pulled HIGH.
You can try use another pin as echo pin like pin 10. For best performance, avoid using SPI pins pin 11 - pin 13 for ultrasonic sensor connection. You can use analog pins for the digital connection.
Generally your coding is okay (well done), except for the line
htmlBody is a part of string and distance is a value. It is better to convert distance to string first before concat it to the string.
You can simply do
htmlBody += (String) distance;
It is a safer bet.
Thanks and Good Luck!
Postby ytphua » Fri Feb 05, 2016 7:01 am
Dear Beng Chet,
Thanks for the advise. It is working now. Truely appreciate.
ytphua
Postby annarosy » Tue Aug 16, 2016 3:57 pm
Hi!
I have successfully communicate my esp8266 module with arduino.It really good and great. Thanks a lot.
annarosy
