BlueBee 4.0 distance estimation
Postby hiphop9686 » Mon Mar 21, 2016 3:31 pm
How do i estimate the distance between 2 Bluebee 4.0 module?
Time of Different Arrival method is it possible ? because RSSI is fluctuating from time to time .
hiphop9686
Re: BlueBee 4.0 distance estimation
Postby Apis210 » Tue Mar 22, 2016 10:26 am
Hi. For distance estimation, I just use RSSI. I do experiment and tabulate the data. Data of the distance and its RSSI Value. Then from the tabulated data, I plot the graph and get the equation from the graph(distance vs RSSI). As the signal is fluctuating, i will do average for the received data. I'm doing it for distance estimation using xbee. but the idea is like that. Just note that it will not get the accurate distance. Just the suggestion. :ugeek:
Apis210
Postby hiphop9686 » Tue Mar 22, 2016 10:46 am
Thank you Apis for the suggestion.
hiphop9686
Postby ober » Tue Mar 22, 2016 1:37 pm
I believe the RSSI (Receive Signal Strength Index) is to indicate signal strength, in many cases, the signal strength does not represent distance, else it will name it as distance index, right?
But that is best signal that may provide you the idea of distance between devices.
