PS2 Controller Starter Kit -Wireless connect with PIC16F877A
Postby SkySoon » Tue Jul 19, 2016 2:00 pm
 * File:   main.c
 * Author: user
 * Created on July 18, 2016, 5:55 PM
#include <xc.h>
//#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
//#pragma config LVP = ON        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
//#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
//#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
//#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
//#pragma config WDTE = OFF
//#pragma config FOSC = XT
#pragma config FOSC = HS       // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bit (BOR disabled)
#if defined(WDTE_OFF)
__CONFIG(WDTE_OFF & LVP_OFF);
#elif defined (WDTDIS)
__CONFIG(WDTDIS & LVPDIS);
#endif
#define MOTOR_R1   RC0     //Control pin for motor, going through motor driver L293D, right motor
#define MOTOR_R2   RC3     //Control pin for motor, going through motor driver L293D, right motor
#define MOTOR_L1   RC4     //Control pin for motor, going through motor driver L293D, left motor
#define MOTOR_L2   RC5     //Control pin for motor, going through motor driver L293D, left motor
#define   p_select      0
#define p_joyl         1
#define p_joyr         2
#define p_start         3
#define p_up         4
#define p_right         5
#define p_down         6
#define p_left         7
#define   p_l2         8
#define   p_r2         9
#define p_l1         10
#define p_r1         11
#define p_triangle      12
#define p_circle      13
#define p_cross         14
#define   p_square      15
#define   p_con_status            28
#define p_motor1      29
#define p_motor2      30
#define SPEEDL      CCPR1L  //PWM register for left motor, to control speed
#define SPEEDR      CCPR2L  //PWM register for right motor, to control speed
void init(void);
void SKPS_PScon(void); //function for PS2 control with SKPS
void forward(void);
void stop (void);
void backward (void);
void reverse (void);
void left(void);
void right(void);
void uart_init(void);   //initialize UART module, 9600 baud
void uart_send(unsigned char data); //send data out via UART
unsigned char uart_rec(void);   //uart receive, 1 byte
unsigned char skps(unsigned char data); //transmit command out to SKPS using UART and wait for response
void disable_global_int(void);  //disable global interrupt
int main()
    init();
    SKPS_PScon(); // mode 5 : PS2 Controller Mode
    BRGH = 1;   //baud rate high speed option
    TXEN = 0;   //enable transmission
    SPBRG = 0x40;   //set baud rate to 9600 at 10Mhz
    TX9 = 0;
    CREN = 1;   //enable continuous reception
    SPEN = 1;   //enable serial port
    RX9 = 0;
    if(OERR == 1)   //check if there is overrun error.
        CREN = 0;
        CREN = 1;   //reset the OERR
    if(RCREG);  //simple read of receive buffer to clear it
        if(RCREG);
    RCIE = 0;   //disable receiver interrupt initially
//function to send out a byte via uart
    while(TXIF == 0);         //wait for previous data to finish send out
    TXREG = data;         //send new data
unsigned char uart_rec(void)      //function to wait for a byte receive from uart
        CREN = 0;
        if(RCREG);
    while(RCIF==0);      //wait for data to received
    return RCREG;      //return the received data
unsigned char skps(unsigned char data)   //function to read button and joystick
{               //information on ps controller
    uart_send(data);
    return uart_rec();
    GIE = 0;    //disable global interrupt
    PEIE = 0;   //disable peripheral interrupt
void init()
    PORTA = 0;
    PORTB = 0;
    PORTC = 0;
    PORTD = 0;
    PORTE = 0;
    // Tris configuration (input or output)
    TRISA = 0b00110011;      //set RA0 and RA2 pin as input,other as output
                                //PR23 Rev2.0 has RA4 and RA5 as input for IR01A
    TRISB = 0b00011111;      //set RB0-RB4 pin as input, other as output
    TRISC = 0b10000000;      //set PORTC pin as output, RC7 is UART Receive pin (input)
    TRISD = 0b00000000;      //set all PORTD pin as output
    TRISE = 0b00000011;         //RE0 and RE1 as input (Switches) RE2 as output (LED)
    // motor PWM configuration
    PR2 = 255;         // set period register for PWM
    T2CON =     0b00000100;   // Timer Control register, timer 2 ON, prescaler = 1:1
    CCP1CON =   0b00001100;   // config for RC1 to generate PWM( for more detail refer datasheet section 'capture/compare/pwm')
    CCP2CON =   0b00001100;   // config for RC2 to generate PWM
    SPEEDL = 0;     //initial PWM is zero
    SPEEDR = 0;     //initial PWM is zero
    stop();   //motors are off
void SKPS_PScon()
    stop();   //stop mobile robot
    uart_init(); //initialize UART
        //button control for mobilility
        if(skps(p_up)==0)   //check "up" button
            forward();      //move forward
            SPEEDL=230;
            SPEEDR=230;
        else if(skps(p_down)==0)   //check "down" button
            backward();         //move backward
            SPEEDL=230;
            SPEEDR=230;
        else if(skps(p_left)==0)   //check "left" button
            left();         //rotate left
            SPEEDL=230;
            SPEEDR=230;
        else if(skps(p_right)==0)   //check "right" button
            right();         //rotate right
            SPEEDL=230;
            SPEEDR=230;
        else
            stop();
            SPEEDL = 0;
            SPEEDR = 0;
    }//while(1)
void forward () //function to enable robot to move forward, do not change the speed
    MOTOR_R1 = 0;
    MOTOR_R2 = 1;
    MOTOR_L1 = 0;
    MOTOR_L2 = 1;
void backward ()    //function to enable robot to move backward, do not change the speed
    MOTOR_R1 = 1;
    MOTOR_R2 = 0;
    MOTOR_L1 = 1;
    MOTOR_L2 = 0;
void left() //function to enable robot to turn left, do not change the speed
    MOTOR_R1 = 0;
    MOTOR_R2 = 1;
    MOTOR_L1 = 1;
    MOTOR_L2 = 0;
void right()    //function to enable robot to turn right, do not change the speed
    MOTOR_R1 = 1;
    MOTOR_R2 = 0;
    MOTOR_L1 = 0;
    MOTOR_L2 = 1;
void stop() //function to enable robot to stop, do not change the speed
    MOTOR_R1 = 0;
    MOTOR_R2 = 0;
    MOTOR_L1 = 0;
    MOTOR_L2 = 0;
My code as shown had downloaded into PIC16F877A. This code mostly copy from the sample code provide by cytron website. Yet, the MOTOR_R1, MOTOR_R2, MOTOR_L1 and MOTOR_L2 do not respond to the button pressed on the joystick. The oscillator i used is 10Mhz with 9600 baud rate. MOTOR_R1, MOTOR_R2, MOTOR_L1 and MOTOR_L2 connected to LED to test whether the pin is set.
SkySoon
Re: PS2 Controller Starter Kit -Wireless connect with PIC16F
Postby ZaM » Tue Jul 19, 2016 6:02 pm
Hi, to make sure the output is working, can you test with with simple coding first. For example like this, and test the output pin with LED or multimeter. If the output can working, please check on this "SPBRG = 0x40; //set baud rate to 9600 at 20Mhz", if you use 10Mhz.
while(1){
MOTOR_R1 = 0;
MOTOR_R2 = 0;
MOTOR_L1 = 0;
MOTOR_L2 = 0;
delay__;
MOTOR_R1 = 1;
MOTOR_R2 = 1;
MOTOR_L1 = 1;
MOTOR_L2 = 1;
delay__;
ZaM
Postby Idris » Wed Jul 20, 2016 8:53 am
Hi SkySoon,
Could you share your references link? Plus, if you can share your hardware setup with clear photo/video, it will helpful.
Postby SkySoon » Wed Jul 20, 2016 10:24 am
ZaM WROTE:Hi, to make sure the output is working, can you test with with simple coding first. For example like this, and test the output pin with LED or multimeter. If the output can working, please check on this "SPBRG = 0x40; //set baud rate to 9600 at 20Mhz", if you use 10Mhz.
while(1){
MOTOR_R1 = 0;
MOTOR_R2 = 0;
MOTOR_L1 = 0;
MOTOR_L2 = 0;
delay__;
MOTOR_R1 = 1;
MOTOR_R2 = 1;
MOTOR_L1 = 1;
MOTOR_L2 = 1;
delay__;
I tried the Port C with blinking LED program and it's work, also the SPBRG = 0x40 due to i'm using baud rate = 9600 with 10Mhz oscillator
SkySoon
Postby SkySoon » Wed Jul 20, 2016 10:29 am
Idris WROTE:Hi SkySoon,
this is the link i used as reference https://docs.google.com/document/d/1S1u ... CaJCY/edit
The main problem i'm facing now is
1. I'm not sure the data transmission between SKPSW-TX and SKPSW-RX as stated in the user manual whereby defined in the code #define p_up 4
2. whether the PIC transmitting the decimal to SKPS module
For the photo of my hardware, the connection should be correct due to the blinking LED program work. Thus, i suspect is my program problem.
SkySoon
Postby Khairul_Tajudin » Fri Jul 22, 2016 5:11 pm
I just try this code into PIC16F877A and its works. You can try this code into your program.
#include <xc.h>    //header file for hitech mid-range pic
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#define _XTAL_FREQ      10000000 //Frequancy of crystal oscillator, for delay, 10MHz
#define LED1        RE2
//skps constant
#define   p_select      0
#define p_joyl         1
#define p_joyr         2
#define p_start         3
#define p_up         4
#define p_right         5
#define p_down         6
#define p_left         7
#define   p_l2         8
#define   p_r2         9
#define p_l1         10
#define p_r1         11
#define p_circle      13
#define p_cross         14
#define   p_square      15
#define p_joy_lx      16
#define   p_joy_ly      17
#define p_joy_rx      18
#define p_joy_ry      19
#define p_joy_lu      20
#define p_joy_ld      21
#define p_joy_ll      22
#define p_joy_lr      23
#define p_joy_ru      24
#define p_joy_rd      25
#define p_joy_rl      26
#define p_joy_rr      27
#define p_motor1      29
#define p_motor2      30
void init(void);
void forward(void);
void stop (void);
void left(void);
void right(void);
//UART functions
void main(void)
    init();     // initiate cnfiguration and initial condition
     //setup UART
    TXEN = 1;   //enable transmission
    TX9 = 0;
    RX9 = 0;
        CREN = 0;
    if(RCREG);
    if(RCREG);
//function to wait for a data from UART
        CREN = 0;
        if(RCREG);
// skps functions
// send a command value to SKPS and wait for a byte of response from SKPS
    uart_send(data);
    return uart_rec();
void init()
    PORTA = 0;
    PORTB = 0;
    PORTC = 0;
    PORTD = 0;
    PORTE = 0;
    LED1 = 0;
// Mode 5: SKPS
// Description: Control the robot using PS2 Controller
void SKPS_PScon()
    //disable_global_int();   //disable global interrupt, we will use polling method
            LED1=1;
            SPEEDL=230;
            SPEEDR=230;
            SPEEDL=230;
            SPEEDR=230;
            SPEEDL=230;
            SPEEDR=230;
            SPEEDL=230;
            SPEEDR=230;
        else
            stop();
            SPEEDL = 0;
            SPEEDR = 0;
    }//while(1)
// Motor control function
// Description : subroutine to set the robot moving direction
    MOTOR_R1 = 0;
    MOTOR_R2 = 1;
    MOTOR_L1 = 0;
    MOTOR_L2 = 1;
    MOTOR_R1 = 1;
    MOTOR_R2 = 0;
    MOTOR_L1 = 1;
    MOTOR_L2 = 0;
    MOTOR_R1 = 0;
    MOTOR_R2 = 1;
    MOTOR_L1 = 1;
    MOTOR_L2 = 0;
    MOTOR_R1 = 1;
    MOTOR_R2 = 0;
    MOTOR_L1 = 0;
    MOTOR_L2 = 1;
    MOTOR_R1 = 0;
    MOTOR_R2 = 0;
    MOTOR_L1 = 0;
    MOTOR_L2 = 0;
Khairul_Tajudin
