Error talking to shield (wifi rev 2.0 esp)
Postby jiafoongwee » Fri Jan 13, 2017 1:20 am
Hi there,
Im using a cytron wifi rev 2.0 shield with and arduino mega.
My arduino IDE is version 1.6.7
TX =D3 RX=D2
Running CytronWifiDemo
Pwr Led = yellow light
TX Led = lights up for a sec when code is uploaded then no light
RX Led = lights up for a sec when code is uploaded then no light
I have no problems with the AT test:
AT
OK
AT+GMR
AT version:0.52.0.0(Jan 7 2016 18:44:24)
SDK version:1.5.1(e67da894)
compile time:Jan 7 2016 19:03:11
OK
But whenever i try it with it CytronWifiDemo:
My serial monitor prints "error talking to shield"
Anyone can shine some light on this?
jiafoongwee
Re: Error talking to shield (wifi rev 2.0 esp)
Postby bengchet » Fri Jan 13, 2017 6:50 am
Check our user manual page 8, it shows the options of RX and TX pins to be used with Arduino Mega.
Postby jiafoongwee » Fri Jan 13, 2017 10:30 pm
My bad, can't believe i missed it.
I tried it on my Arduino Uno and it works fine.
But when i tried it on my mega:
Configuration 1=
RX=D0 and RX=D1.
I also changed to code
if (!WiFi.begin(0, 1))
Sketch gets stuck at uploading.. then..
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_cmd(): short reply, len = 0
avr_read(): error reading address 0x0002
read operation not supported for memory "signature"
avrdude: error reading signature data for part "ATmega2560", rc=-2
avrdude: error reading signature data, rc=-1
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
then ..
vrdude: ser_open(): can't open device "\\.\COM12": Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0d
Configuration 2=
RX=D0 and RX=D1.
With code below
if (!WiFi.begin(2, 3))
sketch gets this error
Any idea whats wrong?
jiafoongwee
Postby bengchet » Sat Jan 14, 2017 9:36 am
This is the common small mistake usually made by Arduino users. Remember, when uploading program to Arduino, D0 and D1 must be left unconnected. If not, the process will be interrupted as the situation you have now. A few solutions to this:
1) If you insist to use D0 and D1, unplug the shield everytime before you upload the program. Plug the shield back when you are done.
2) Choose other pins for RX and TX, for Arduino Mega, 10, 11, 12, 13 works fine.
Option 2 is recommended.
