database connection error
Postby izzat » Mon Mar 06, 2017 2:10 am
i always get this error."--> connection failed". i guess it cause by this statement "if (client.connect(server, 80))". what you guys think ?
arduino code
#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <CytronWiFiServer.h>
#include <SoftwareSerial.h>
#define trigPin 13
#define echoPin 12
ESP8266Client client;
//connection to wifi
const char *ssid = "iPhone";
const char *pass = "kasipecah10";
IPAddress ip(172, 20, 10 , 1);
//ultrasonic sensor
void sensorDetection()
  long duration, distance;
  digitalWrite(trigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10); // Added this line
  duration = pulseIn(echoPin, HIGH);
  distance = (duration / 2) / 29.1;
  if ((distance <= 7))
    saveDb();
    Serial.print(distance);
    Serial.println(" cm");
    delay(5000);
  else
    Serial.println ("range is to far, try again with short range");
  delay(1000);
void setup() {
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  while (!Serial) {
  if (!wifi.begin(2, 3))
    while (1);
  Serial.print(F("Mode: "));
  Serial.println(wifi.getMode()); // 1- station mode, 2- softap mode, 3- both
  wifi.config(ip);
  if (!wifi.connectAP(ssid, pass))
    while (1);
  Serial.print(F("Connected to ")); Serial.println(wifi.SSID());
  wifi.updateStatus();
  sensorDetection();
  sensorDetection();
//connection and save to database
char server[] = "172.20.10.10"; // IMPORTANT: If you are using XAMPP you will have to find out the IP address of your computer and put it here (it is explained in previous article). If you have a web page, enter its address (ie. "www.yourwebpage.com")
void saveDb()
  // Connect to the server (your computer or web page)
    Serial.print("You Have 1 Mail!\n");
    client.print("GET /write_data.php?"); // This
    client.print("value="); // This
    client.println(" HTTP/1.1"); // Part of the GET request
    client.println("Host: 172.20.10.10"); // IMPORTANT: If you are using XAMPP you will have to find out the IP address of your computer and put it here (it is explained in previous article). If you have a web page, enter its address (ie.Host: "www.yourwebpage.com")
    client.println("Connection: close"); // Part of the GET request telling the server that we are over transmitting the message
    client.stop();    // Closing connection to server
  else
    // If Arduino can't connect to the server (your computer or web page)
    Serial.println("--> connection failed\n");
php code
<?php
    // Prepare variables for database connection
    $dbusername = "root";  // enter database username, I used "arduino" in step 2.2
    $dbpassword = "";  // enter database password, I used "arduinotest" in step 2.2
    $servera = "localhost"; // IMPORTANT: if you are using XAMPP enter "localhost", but if you have an online website enter its address, ie."www.yourwebsite.com"
    // Connect to your database
    $dbconnect = mysql_pconnect($server, $dbusername, $dbpassword);
    $dbselect = mysql_select_db("test",$dbconnect);
    // Prepare the SQL statement
    $sql = "INSERT INTO history (value) VALUES ('".$_GET["value"]."')";
    // Execute SQL statement
    mysql_query($sql);
izzat
Re: database connection error
Postby izzat » Mon Mar 06, 2017 2:16 am
i tried to declare char y = 1 and change this statement "if (client.connect(server, 80))" to -> if (y = 1) and i get "You Have 1 Mail!". That why i think the problem is with this statement "if (client.connect(server, 80))". but i dont know what is the problem with this statement.
izzat
Postby bengchet » Mon Mar 06, 2017 10:05 am
You can try a few things here.
1) Remove wifi.config(ip), allow your shield gets random IP address assigned by router.
2) Change char server[] ="172.20.10.10" to IPAddress server(172, 20, 10, 10).
3) Make your request into one liner such as client.println("GET /write_data.php?value= HTTP/1.1/r/nHost: 172.20.10.10/r/nConnection: close")
4) I don't know if you are trying to get the data from the database, but seems like I can't find the code for reading the result from the database. You might need do some coding. Before reading the result, avoid using client.stop(). Look at CytronWiFiDemo sketch void clientTest() for the example to retrieve the result.
Hope it helps. Thanks.
