CYTRON WIFI SHIELD REV2.0 client problem
Hello,
I just bought Cytron Wifi Shield Rev2.0 last week. I used it with Arduino Mega2560. I got no problem connecting to wifi. However, i have a problem to connect the arduino to a server as a client. I just try to run the all the client example, it give respond "Failed to connect to server". I run HTTPSClient example, HTTPSGoogleform example and CytronWifiDemo example and all of it give the same respond.
below is the HTTPS example code.
The other code is the same as the example in the library. By the way, i also try to run the SimpleWifiWebserver example, it can run smoothly.
Can anyone help me to solve this problem. This is because i want to use client library for my project. Thank you in advance.
- CODE: SELECT_ALL_CODE
* HTTP over TLS (HTTPS) example sketch
* This example demonstrates how to use
* secure_connect function to access HTTPS API.
* We fetch and display the status of
* esp8266/Arduino project continuous integration
* build.
* Created by Ivan Grokhotkov, 2015.
* This example is in public domain.
* Modified by Ng Beng Chet, 2016
#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <SoftwareSerial.h>
const char* ssid = "Connectify-me";
const char* pass = "syaza1994";
const char* host = "api.github.com";
const int httpsPort = 443;
void setup() {
while (!Serial) {
if(!wifi.begin(10, 11))
Serial.print(F("Connected to: "));Serial.println(wifi.SSID());
ESP8266Client client;
Serial.println(host);
if (!client.secure_connect(host, httpsPort))
client.stop();
return;
String url = "/repos/esp8266/Arduino/commits/master/status";
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: BuildFailureDetectorESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
//set 5 seconds timeout for response from server
int i=5000;
delay(1);
if(i==1) {
Serial.println(F("Timeout"));
client.stop();
return;
if(client.available())
if (client.find("\r\n\r\n"))
Serial.println(F("headers received"));
String line = client.readStringUntil('\n');
if (line.startsWith("{\"state\":\"success\""))
Serial.println(F("esp8266/Arduino CI successfull!"));
else
Serial.println(F("esp8266/Arduino CI has failed"));
Serial.println(F("reply was:"));
Serial.println(F("=========="));
Serial.println(line);
Serial.println(F("closing connection"));
//flush the rest of received data
while(client.available()>0)
client.flush();
client.stop();
void loop() {
