Espresso Lite V2 espcomm error
Postby ssloo77 » Mon May 22, 2017 12:48 pm
When i verify the sketch it show no error but during uploading it show this error .
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
ssloo77
Re: Espresso Lite V2 espcomm error
Postby bengchet » Mon May 22, 2017 9:56 pm
May I know which USB-Serial Adapter you are using? UC00A or UC00C? Which system you are running on your PC? Windows, Mac, Linux?
You got this error when you upload the sketch for first time?
Postby ssloo77 » Mon May 29, 2017 7:18 pm
I am using UCOOC and windows PC. I solved the problem after change usb cable and restart the arduino software. Thanks for your reply.
ssloo77
Postby Idris » Thu Jun 01, 2017 10:48 am
Hi ssloo77,
Glad to hear that. :)
Postby Sukuri » Mon Nov 13, 2017 1:40 pm
Hi there,
I just bought Espresso Lite V2.0 with UC00A R3, after install all libraries using Arduino IDE v1.8.1, then connect the usb, I found the COM Port is not detected.
Can I know what is actually the problem?
Sukuri
Postby bengchet » Mon Nov 13, 2017 2:42 pm
Com port not detected, normally comes from few situation.
1) UC00A R3 driver is not installed in PC
2) USB cable used to connect UC00A to PC
You can try check if the driver is ady being installed. When driver is installed successfully and connect USB cable to UC00A, you should be able to see COM port ( that time Espresso Lite not needed to attach yet)
Postby Idris » Mon Nov 13, 2017 2:44 pm
Hi Sukuri,
Could you disconnect all, and just connect between your PC/laptop and UC00A? If still can't detect try with other PC/laptop.
Postby Sukuri » Mon Nov 13, 2017 2:45 pm
bengchet WROTE:Hi,
Thanks for that.
I think the driver is the problem, can I know where can I get the driver to re-install?
Sukuri
Postby Sukuri » Mon Nov 13, 2017 2:47 pm
Idris WROTE:Hi Sukuri,
I've tried connect with laptop only, but still COM port not detected. I don't think my usb port is the problem cause it works with arduino.
Sukuri
Postby Idris » Mon Nov 13, 2017 3:14 pm
Hi, did you try with bengchet suggestion? Try to re-install the driver.
Could you printscreen your device manager?
