SHIELD-ESP-WIFI REV 2.0 and client secure
Postby wxlf366 » Mon Aug 21, 2017 1:34 am
hi.
im using this shield to connect with telegram bot library which is needed to use " WiFiClientSecure " as a client. when i use library WiFiClientSecure.h. i got error when uploading.
wxlf366
Re: SHIELD-ESP-WIFI REV 2.0 and client secure
Postby bengchet » Tue Aug 22, 2017 3:54 pm
Looks like the library is only compatible if you program ESP8266 directly. Try look for alternative library which supports Arduino + Shield.
