CytronWiFiShield failed to make request to HTTPS endpoint
Postby wmfairuz » Wed Nov 15, 2017 11:49 am
I'm using CytronWiFiShield for my Arduino project and trying to run the https client example but failed.
Serial Output:
Start wifi connection
Connected to: ABC Unifi
IP address: 192.168.0.161
Connecting to api.github.com
Failed to connect to server.
Is there any extra step to do for https requests? (eg. cert)
Thanks
wmfairuz
Re: CytronWiFiShield failed to make request to HTTPS endpoin
Postby bengchet » Thu Nov 16, 2017 10:31 am
Which version of shield you are using, version 1 or 2? Please use CytronWiFiDemo in examples to check your shield AT version.
You can try this user manual on firmware installation for SSL support. Please complete all the steps in part 8 before proceed to use this shield with Arduino.
Note: Above all, please use CytronWiFiDemo to verify your valid connection to servers before doing firmware installation, the sketch uses http server.
